Hello Guest it is November 24, 2026, 03:28:02 PM
Author Topic: Help to finish a button  (Read 49730 times)
Offline Alexi
  •  10 10
Re: Help to finish a button
« Reply #10 on: February 18, 2021, 08:30:39 AM »
Code: [Select]
'*** turn soflimit's off if they are on
Dim SoftLimitswhereon As Boolean
If GetOEMLed(23) Then
   DoOEMButton(119)
   SoftLimitswhereon = True
End If
If GetOEMLed(832) then
    Code "G91 G1 Z-10 F100"
    Code "G90"
    While IsMoving()
    Wend
End If
Dobutton( 24 ) ' ZeroZ
While IsMoving()
Wend
Sleep 500
ZDRO = 85 'variavel dro maquina
ZWDRO = 2 'variavel dro trabalho
Z = GetOEMDRO( ZDRO ) 'passa o valor do dro maquina
Call SetDro (ZWDRO, Z) 'passa o valor do dro maquina
Sleep 500
'clear x-axis Limit Switch if needed
If GetOEMLed(830) then
    Code "G91 G1 X10 F100"
    Code "G90"
    While IsMoving()
    Wend
End If
Dobutton( 22 ) ' Zerox
While IsMoving()
Wend
Sleep 500
XDRO = 83 'variavel dro maquina
XWDRO = 0 'variavel dro trabalho
X = GetOEMDRO( XDRO ) 'passa o valor do dro maquina
Call SetDro (XWDRO, X) 'passa o valor do dro maquina
Sleep 500
'clear y-axis Limit Switch if needed
If GetOEMLed(831) then
    Code "G91 G1 Y10 F100"
    Code "G90"
    While IsMoving()
    Wend
End If
Dobutton( 23 ) ' ZeroY
While IsMoving()
Wend
Sleep 500
YDRO = 84 'variavel dro maquina
YWDRO = 1 'variavel dro trabalho
Y = GetOEMDRO( YDRO ) 'passa o valor do dro maquina
Call SetDro (YWDRO, Y) 'passa o valor do dro maquina
Sleep 500
Code "G28"
While IsMoving()
Wend
Sleep 500
'*** turn soflimit's back on if they where on
If ((Not GetOEMLed(23)) And (SoftLimitswhereon = True)) Then
   DoOEMButton(119)
   Sleep(500)
End If
Code   "( ZERO DONE )"
I forgot that one and i could`t test it yet, the factory still closed.
Now i think it is done
