Hello Guest it is October 24, 2026, 05:53:01 PM
Author Topic: Spindle speed not correct  (Read 43275 times)
Re: Spindle speed not correct
« Reply #30 on: January 27, 2021, 01:09:10 PM »
ordered! Please allow some shipping time and I can tell you that I will make it work :) I don't care what it takes! if I have to point at it and wag my finger aggressively at it I will do it ;) I suspect next week I should see it .
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #31 on: January 29, 2021, 07:11:03 AM »
looks like I will have my VFD on the 4th if the shipping lie is correct.
www.machsupport.com
« Reply #32 on: January 29, 2021, 12:09:08 PM »
Lets hope it comes prepared to have a finger wagged at it!
« Reply #33 on: January 29, 2021, 12:48:39 PM »
I got a spindle to test it with... MAN that was fast! I will have wires in the spindle waiting for a dump electrons from the VFD ! This thing is small for 2.2kw, 3HP of pure fun!
I have a Germo usb to 422/485 converter somewhere here that I will use in my test as well.
Waiting like a kid for Xmas
www.machsupport.com
« Reply #34 on: February 08, 2021, 11:21:35 PM »
The VFD is in and we are starting to setup the test. I am using the opportunity to teach but will also give the settings here. I did get a cheaper 485 converter as an alternative so we can have a budget friendly option.
Trying not to forget anything here.
www.machsupport.com
« Reply #35 on: February 09, 2021, 04:22:31 AM »
I’m looking forward to seeing how you get on - I still haven’t managed to get modbus talking to the vfd, and haven’t found any more info on the address registers.
« Reply #36 on: February 09, 2021, 06:07:47 AM »
The manual for the drive is not great but I will crack it ;)
www.machsupport.com
« Reply #37 on: February 09, 2021, 01:30:30 PM »
Well that is nonstandard Modbus... I am not impressed! I am looking into what we need to change to be able to talk to the drive. More later :)
www.machsupport.com
« Reply #38 on: February 09, 2021, 03:10:07 PM »
Well after digging on the web we have found the docs for the VFD. We are going to make a new plugin for the drive because everyone seems to be using this drive! They are not great but they seem good enough LOL.
I hope we can test this in the week to come.
More when I know more ;)
www.machsupport.com
« Reply #39 on: February 10, 2021, 01:54:23 AM »
HuanYang are famous for having non-Modbus compliant comms, that's the reason for the special plugin in Mach3
for these VFDs.
The manufacturers must have taken a lot of heat over the non standard comms because they have released later models
which are compliant.....just they are more expnsive....so people still buy the el-cheap ones with this result.
I'll try to find the model identifier, its something like HuanYang nnnn.GM, with the GM, or some other accronym signaling
compliance with the Modbus standard.
