Hello Guest it is September 30, 2026, 11:33:35 PM
Author Topic: A axis stepper rotation error  (Read 6858 times)
« on: January 19, 2021, 01:41:48 PM »
Trying to use a axis for rotary scan.  I aligned X, Y axis to center of plate.  My A axis stepper is over rotating for a 360 degree program.  One full rotation of plate registers as ~300 degrees in controller.  The belts and gears are not slipping and there doesn't seem to be any tangible fault.
"Everything will be okay in the end.  If it's not okay, it's not the end"   -unknown
Offline TPS
  •  2,627 2,627
Re: A axis stepper rotation error
« Reply #1 on: January 20, 2021, 02:25:59 AM »
then your step'/per for the a-axis are not set correctly.
