Hello Guest it is September 18, 2026, 09:12:46 PM
Author Topic: Mouse MPG Module  (Read 23225 times)
Re: Mouse MPG Module
« Reply #10 on: February 02, 2021, 07:07:46 PM »
I will post a link tomorrow :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: February 03, 2021, 09:19:29 AM »
Okay you asked for it! I guess it works as you would like. I made it so you can map it to an MPG in configure->controller MPG's . Set the MPG to the Keyboard/MouseWheel and one Click per , Acceleration to 100 Velocity at 100. Also it would be a good idea to enable it!
This will be taken down once we are done and it is in the release...
« Last Edit: February 04, 2021, 07:36:06 AM by Brian Barker »
www.machsupport.com
« Reply #12 on: February 03, 2021, 04:24:08 PM »
thanks. I think your idea to map a key to toggle it on or off makes sense than having it always listening. it would be much safer that way.
« Reply #13 on: February 03, 2021, 07:14:41 PM »
I will do a Key or an output you can map I guess. Sound good? I will do that when I get in tomorrow.
www.machsupport.com
« Reply #14 on: February 03, 2021, 07:46:19 PM »
okay thanks i think the key map would be easier to work with. thanks for the work you put in this.
« Reply #15 on: February 04, 2021, 11:29:41 AM »
Here you are with 300% more settings to enable and disable the wheel. I added a button action to do the following:
1.) Toggle the Mouse Wheel enable
2.) Mouse Wheel On
3.) Mouse Wheel Off
I put the code in and your job is to test it :)
www.machsupport.com
« Reply #16 on: February 05, 2021, 07:35:29 AM »
This had no ill effects so it is now in the versions after 4690 ;) . We are testing for release so we should have this on the web if all goes well in testing. All features are cut off for now.
www.machsupport.com
Offline jbuehn
  •  101 101
« Reply #17 on: February 05, 2021, 02:32:15 PM »
Is 4609 what you're release testing right now?
« Reply #18 on: February 05, 2021, 02:38:43 PM »
It is but we will have a new version out soon!
www.machsupport.com
« Reply #19 on: February 05, 2021, 07:08:02 PM »
...I put the code in and your job is to test it :)
It's working great after testing it some. I used it for a bluetooth device that emulates a Mouse/Keyboard to simulate a MPG.
Here's demo:
https://www.youtube.com/watch?v=MvadVEjZ93Q
Thanks for adding this feature!
