Hello Guest it is October 15, 2026, 12:55:43 AM
Author Topic: [Help] One axis screen  (Read 62066 times)
Re: [Help] One axis screen
« Reply #10 on: January 19, 2021, 08:02:16 AM »
If I copy&paste your g-code (that have 4 entrys) it only shows me 3 in the list, then i check again to press GO and anything is happening, actual length is showing -2.55 and your keypad only shows 1 time :/
Maybe something wrong with my profile?
im opening mach3, load the profile, and then i go to view --> load screen
Offline TPS
  •  2,627 2,627
« Reply #11 on: January 19, 2021, 08:10:20 AM »
maybe E_stop not reseted, Looks like your machine is not moving at all.
Offline TPS
  •  2,627 2,627
« Reply #12 on: January 19, 2021, 08:11:22 AM »
-use load wizard
-select baldestop
to run my wizard
« Reply #13 on: January 19, 2021, 08:15:51 AM »
Its doing exactly the same...
i will try to record a video and upload here
Offline TPS
  •  2,627 2,627
« Reply #14 on: January 19, 2021, 08:17:28 AM »
you will have to upload the Video to Youtube, will be to large for here.
try to upload a screenshot of mainscreen (1024.set) and of Config -> Ports&Pins -> Motor Outputs here
« Last Edit: January 19, 2021, 08:19:05 AM by TPS »
