Hello Guest it is October 30, 2026, 08:05:01 AM
Author Topic: CNC 5040 z-axis problem  (Read 102961 times)
Re: CNC 5040 z-axis problem
« Reply #10 on: January 03, 2021, 07:09:00 AM »
Next question is about cuting depth, it is perfect 1/2 from set. If i set up cut 18mm plywood machine cut only 9mm. if i set up 36mm machine cut 18mm plywood without problem.
 I need change z- axis steps increase in Motor tuning and setup?
Offline ZASto
  •  434 434
« Reply #11 on: January 03, 2021, 11:26:00 AM »
Yes, you have to double Steps Per.
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
