Hello Guest it is October 22, 2026, 04:26:43 PM
Author Topic: M62/63 Command issue  (Read 17717 times)
Offline Rob G
  •  17 17
Re: M62/63 Command issue
« Reply #10 on: January 04, 2021, 02:15:54 PM »
Jimmy,
Thank you for your results!  I spent quite some time with PoKeys development this morning.  We found both of the boards we ere testing with were working as expected in conjunction with Mach4.  I am however going to add a scope to the testing as you did and I will make sure I am still getting the results I was seeing today.  I will post back when I get this tested.
Rob G
« Reply #11 on: January 04, 2021, 02:58:49 PM »
Jimmy,
Rob G
Thanks again for all your help.
I forgot to add one item as well. When under Pokeys Pulse Engine. I can click on the 4 individual OC outpus. When I click on OC 1 the LED indicator on the Pokeys Control board OC 4 will activate. Its not activating the correct OC outputs. I have attached two photos of this.
« Reply #12 on: January 11, 2021, 01:02:28 PM »
This is has now been resolved. The issue was a load error for the wx4.set. I removed Mach 4 and did a clean install. M62 / M63 are know functioning as they should.
Thanks for all the help on this issue Rob and Pokeys.
Jimmy
