Hello Guest it is November 24, 2026, 12:03:22 PM
Author Topic: Cutter compensation issue  (Read 7093 times)
« on: December 01, 2020, 08:23:28 AM »
Hi all,
I am having issues with cutter compensation. We are using an end mill to rough around a waterjet cut blank. The blank is a complex shape with multiple radii. When using cutter compensation, the smaller radius have a circle path drawn, cutting into the material. When turning off compensation, the part appears normal. Any ideas what could be going on?. Any help would be appreciated.
-Mark
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Cutter compensation issue
« Reply #1 on: December 02, 2020, 11:37:41 AM »
The cutter comp only works if the tool radius is smaller than the smallest radius on the part.
« Reply #2 on: December 02, 2020, 05:27:37 PM »
Yes, the smallest part radius is larger than the tool radius.
« Reply #3 on: December 03, 2020, 12:50:58 AM »
Post the Gcode..
