Hello Guest it is November 24, 2026, 06:08:23 PM
Author Topic: Mach 3 issue with very large (22 meg) g-code  (Read 17477 times)
« on: October 05, 2007, 03:20:40 PM »
I had an issue this morning with my mill missing steps.  When I ran a specific code it ran like dog snot.  Missed steps  sounded ugly ect.  I tried running a code I knew that worked  and it ran fine.  Went back to my other code....... crappy.   Rebooted,  re-ran.... ugly still.
I noticed that the problem code was 22 + meg in size.   changed to peramiters and got it down to 12 meg and now its running fine.   My first though was a computer issue  so I ran the signal test in mach.   No spikes.
Is there an issues with large g-codes?   Something I need to know about?
The computer is an AMD 2100+  with 1 gig of DDR ram.
I run lots of large code  and would like to head this issue off now,  rather then when I need something.  I machine wax  so I know that its not a material hardness issue.  Even when running the code at 50% feedrate the motors stalled and sounded just bad!
Any Ideas?
Re: Mach 3 issue with very large (22 meg) g-code
« Reply #1 on: October 05, 2007, 04:25:26 PM »
Might be the graphics on your PC choking. What do you use for Graphics? Is it onboard or do you have a graphics card? If so, do you have the specs? The only other thing I can think of right off is something in your file that Mach doesn't like. What did you change to get the file to half size?
« Reply #2 on: October 05, 2007, 04:30:06 PM »
the video card is an AGP ATI Radeon 7000 series 32 meg
I re wrote the toolpath with less stepover  and changed the actual part so it wasnt so high in Z and lowered the resolution of the part.  All these things added up to a G code that was half the original size
« Reply #3 on: October 05, 2007, 05:00:28 PM »
Have you tried to turn off some of the toolpath screen features and see if it helps?
« Reply #4 on: October 05, 2007, 05:09:52 PM »
turn off....... hummm.......  I dont really use the visual toolpah screen... let me see if that does it.......
can you tell me what to turn off so I dont screw it up?
« Last Edit: October 05, 2007, 05:12:12 PM by fixittt »
« Reply #5 on: October 05, 2007, 05:25:31 PM »
Just remember what options you have checked in config, toolpath and uncheck all of them.
« Reply #6 on: October 05, 2007, 07:19:43 PM »
unchecked them all,  and now when I load the 12 meg file  I get the watchdog has been triggered.
re ran the driver test and it looks really flat.    CPU is regestered at a 1.7   (AMD 2100 +)  AMD never could get the numbers right!
« Reply #7 on: October 05, 2007, 07:42:34 PM »
Try turning the toolpath off via the button on the Diagnostics page. On my version its just above the reset button but could be placed elsewhere depending on version.
« Reply #8 on: October 05, 2007, 07:46:11 PM »
Also not sure what you mean regarding AMD andnot getting  the numbers right but a 2100+ is at the correct clock when runing at 1733MHz.
