Hello Guest it is October 24, 2026, 05:52:54 PM
Author Topic: Mach 4 and 2 vfd Spindles setup  (Read 24581 times)
Offline DAAD
  •  105 105
Re: Mach 4 and 2 vfd Spindles setup
« Reply #10 on: November 19, 2020, 12:10:43 AM »
will look into it!
Offline DAAD
  •  105 105
« Reply #11 on: November 27, 2020, 08:10:54 AM »
Have my machine up and running with 2 spindles.
Installed a relayboard to take care of the swapping and made the link with the outputs needed in my module.
The hard thing was to swap the spindle range. It would not want to use (swap) the data in the table.
I've used some Api's to force the spindle settings when switching from s1 to S2.
Problem solved!
Keep Safe,
Adam
« Reply #12 on: May 18, 2024, 05:34:49 AM »
Hello DAAD, can you help with the api's please? Do you have an example? Thanks in advance ;)
