Hello Guest it is November 27, 2026, 07:24:24 AM
Author Topic: Unknown Word starting with a , Block  (Read 42619 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Unknown Word starting with a , Block
« Reply #10 on: November 05, 2020, 09:58:33 AM »
The Mach3 parser is a bit limited and soon gets confused.
It is not keen on any real numbers in a calculation.
#100=-1 is also a problem.  #100 = [1 * -1] works.
The safest way is to keep the lines simple and always put values into #vars with lots of enclosing square brackets.
« Reply #11 on: November 06, 2020, 02:53:39 AM »
Thanks Graham. Will keep that in mind.
If A is a success in life, then A equals X plus Y plus Z.
                               Work is X: Y is play and Z is keeping
                                                             your mouth shut.
