Hello Guest it is October 21, 2026, 01:38:27 AM
Author Topic: Index/Timing/Encoder Pokeys57CNC  (Read 7540 times)
« on: October 25, 2020, 06:50:23 AM »
Hi, I have connected a mechanical rotary encoder on the lathe, connected to Pokeys57 CNC. The encoder is sending correct signals which I checked in the Poscope. Now in the MACH3 encoder configuration I chose "ultra fast encoder" in the pokeys interface...but i'm now struggling with the DRO to choose. Neither Strue DR0 (#39) nor the MPG 2 Count DRO (#102) are feeding any signal to the Index indicator and the STrue display in MACH3Turn. With DRO 102 i can at last see in MACH3Mill "Settings" that correct data is fed. What DRO do I have chose and what other configuration do I have to make in Mach3?
Re: Index/Timing/Encoder Pokeys57CNC
« Reply #1 on: November 18, 2020, 10:31:16 AM »
Thank you I downloaded the installation successfully
