Hello Guest it is October 21, 2026, 09:04:13 PM
Author Topic: Mach4 in factory automation  (Read 6810 times)
« on: October 23, 2020, 03:35:14 PM »
Hello,
First, I am new to Mach4 and Mach in general.
I have a vendor supplying an XYZ gantry for doing spot welding and they are including Mach4 Industrial. I would like to automate loading of programs (recipes) and interaction with the the motion software from our PLC and SCADA system.
I would love some feedback on how to approach this. Maybe Read a Modbus register in a master G-Code program that then calls subprograms? Ideas and pointers to existing similar applications welcome.
Thank you!
Tanda
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach4 in factory automation
« Reply #1 on: October 24, 2020, 08:48:14 PM »
There are many way to do this, if you only want to run one program for ever in a loop it can be loaded from the screen load code and executed or you can have a modbus call to load and execute a program of a button on screen to load and run a file, I would email mach4 support and they will probably have this type of thing ready to use.
« Reply #2 on: October 25, 2020, 01:40:26 AM »
we use c# application that control mach by Api
so we can load files ,change ,stop....do every thing we need
also control more then one mach system paralel
« Reply #3 on: October 25, 2020, 03:36:44 PM »
Thanks for the response. Yes, with a bit more research I found some videos on the MACH4 internals and architecture which led me to the API. Looks like they have done a good job of exposing the functions in the CORE though the API. I've already specified MACH4 Industrial to drive another machine we are building inhouse which is doing weld inspection. I think it's just what I was looking for which is a motion platform that interprets G-Code but allows me to drive it from, and integrate it with, external applications. Looks like I am going to be up to my eyeballs quickly in MACH4 development. Wish me luck!
