Hello Guest it is October 21, 2026, 06:49:09 PM
Author Topic: Cutter Compensation not reading tool diameter  (Read 15695 times)
Re: Cutter Compensation not reading tool diameter
« Reply #10 on: October 23, 2020, 08:15:57 AM »
I can't show an actual photo, due to company confidentiality policy, but I'm attaching a drawing that might clear it up some.
Thank you regarding avoiding G41/G42.  That was what I was thinking.  I can write GCode that could increment a # variable or a lua dialogbox that allow the user to input new values.  A this is a single use machine it shouldn't be a problem.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: October 23, 2020, 12:55:05 PM »
Okay, if you can write code then all you need to do is add a #var to your code.
# Numbers for the tool diameter offsets start at 13000 + the offset number so D2 offset would be #13002
Then you remove the G41/42's and you add something like this G01 Y[#13002] F1. or G01 Y-[#13002] F1. in your code.
Your code will look something like this :-
g0 g49 g40 g17 g80 g50 g90
g04 p2.
g53 g00 z0
M03
M08
G54 g00 g90 x0 y0.01 a0
z1.
g01 z-.25 f10.
y-[#13001] (offset Dia1)
a720. f2000.
x0y0
y[#13002] f10. (offset Dia2)
a0. f2000.
Etc......
« Reply #12 on: October 23, 2020, 01:18:25 PM »
That's great, I didn't realize the Diameters were a #var too!
Thank you!
