Hello Guest it is November 03, 2026, 02:08:04 PM
Author Topic: Homing and Limit Configuration  (Read 19348 times)
« on: October 13, 2020, 04:26:04 AM »
I have a Sherline 5410 (metric) milling machine running through a cheap Chinese breakout board by Bitsensor.com model BSMCEO4U-PP.  I have all the axes and pin setup correcting where I can jog back and forth through Mach3.  However; my problem is setting up my homing/limit configuration.  I have looked at many online tutorials and some of them can be a little confusing to a person unifiliar to Mach3.  Dose anyone know the proper setup for homing/limit configuration for a Sherline Mill or should I say does anyone know of a good tutorial step-by-step guide for a newbie to Mach3?
Offline TPS
  •  2,627 2,627
Re: Homing and Limit Configuration
« Reply #2 on: October 13, 2020, 07:16:40 AM »
  :)  Thank you for the help.
« Reply #3 on: January 18, 2021, 10:27:41 AM »
This is a link to a manual for the BSMCEO4U
http://vancura.biz/files/BSMCEO4U%20Install%20Manual-converted%20wjv%202.2.pdf
It should have everything you need to get running.
If not contact me for personal help.
Bill
Pixel Tamer
« Reply #4 on: January 18, 2021, 07:39:39 PM »
Bill,
Thank you for your reply and link.  I fiddles with the settings and got everything working with trial and error.
« Reply #5 on: January 18, 2021, 07:52:09 PM »
Reading through the Mach3 Version 3.x Macro Programmers Reference Manual
I found 'CoupleSlave' and conjured up this possible REFALLHOME sequence.
The sequence should allow you to have all Limit and Home switches on the same input.
DoButton( 24 )      ' Home Z [DoOEMButton(1024)]
DoButton( 23 )      ' Home Y [DoOEMButton(1023)]
DoButton( 22 )      ' Home X with slave
CoupleSlave(0)      ' Disconnect A From X
DoButton( 22 )      ' Home X [DoOEMButton(1022)]
DoButton( 25 )      ' Home A [DoOEMButton(1025)]
CoupleSlave(0)      ' Connect A To X
DoOEMButton(133)     ' Set X=0
DoOEMButton(134)   ' Set Y=0
DoOEMButton(135)   ' Set Z=0
One thing you may want to consider.  Limit switches are more reliable when wired in series and normally closed. Some users have complained about false triggers on open switches, and problem went away when using Normally closed.
Anytime,
Bill
Pixel Tamer
« Reply #6 on: January 18, 2021, 09:41:08 PM »
Hello Bill,
Thank you this information it is very useful, I try to implement it with my configuration.
