Hello Guest it is October 21, 2026, 12:47:36 PM
Author Topic: NEED HELP Mach3 and 2HSS86H problem on AXBB-E  (Read 12865 times)
Offline Alexi
  •  10 10
« on: September 21, 2020, 05:09:46 AM »
Hello,
Can anyone help i wonder?
I am trying to connect drivers to mach 3 to test them for first move but i harder then i thought.
Motor and encoder are wired according to label that is in motor.
This is the kit that i have: https://www.aliexpress.com/item/32802045718.html?spm=a2g0s.issue_5ptha.0.0.33334c4dEAMGhH
Configs that i am using are:
Pul+ Pin9
Pul- 5V0
DIR+ Pin19
DIR- 5V0
Switch in driver are config to default (400 steps)
Mach3 is config to 100 steps to mm velocity to 2000 and accel to 200. Step pulse and Dir pulse are both set to 5.
I believe AXBB-E is properly config because i have home induction switch and are working as supposed. I can activate them and mach3 is recognizing them
The problem is when i try to rotate motor in arrow keys i get driver error alarm and it blinks 7 times.
I tried several configs and kernel speeds but no success.
Any help is welcome.
Alex
EDIT: Link corrected.
« Last Edit: September 21, 2020, 06:12:08 AM by Tweakie.CNC »
Offline reuelt
  •  520 520
Re: NEED HELP Mach3 and 2HSS86H problem on AXBB-E
« Reply #1 on: September 21, 2020, 05:38:23 AM »
You also need to connect the ENABLE SIGNALS
ENA+
and
ENA-
"the gift of God is eternal life through Jesus Christ our Lord"
Offline TPS
  •  2,627 2,627
« Reply #2 on: September 21, 2020, 05:44:53 AM »
btw your link is not working.
Offline Alexi
  •  10 10
« Reply #3 on: September 21, 2020, 06:04:36 AM »
Hi Reuelt,
Thanks for our help.
I believe i don“t need to connect the enable signals because driver is enabled and motor shaft is locked when i start mach3. The problem is when i try to move axis it will only spin a small amount and driver gives error. Red led blinks 7 or 8 times not sure.
I tested all 3 drivers and same result for all.
Here is the link of my drivers
 https://www.aliexpress.com/item/32643410928.html?spm=a2g0o.productlist.0.0.4e0b738fSsKX2p&algo_pvid=b7c9c0ce-759a-49f1-abfe-a02615a2d6f8&algo_expid=b7c9c0ce-759a-49f1-abfe-a02615a2d6f8-10&btsid=0bb0623316006861580107870e66f0&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Thanks for all
Alex
Offline TPS
  •  2,627 2,627
« Reply #4 on: September 21, 2020, 06:07:57 AM »
have you tryed to Change Motor direction by swapping A and B wire's ?
Offline Alexi
  •  10 10
« Reply #5 on: September 21, 2020, 06:32:51 AM »
You mean motor coils?
Change A+ to B+ and A- to B- ?
Offline TPS
  •  2,627 2,627
« Reply #6 on: September 21, 2020, 06:34:44 AM »
yes exactly, because i think rotation of Motor and Feedback does not match.
Offline Alexi
  •  10 10
« Reply #7 on: September 21, 2020, 06:49:07 AM »
Oh ok i will try that and post for results.
Offline Alexi
  •  10 10
« Reply #8 on: September 22, 2020, 12:01:46 PM »
IT WORKED.
It looked like magic, all issues were gone, thanks.
Alex
