Hello Guest it is October 21, 2026, 08:55:52 AM
Author Topic: NEED HELP!!! Setting up Mach3 with Gecko G320X and servos for a 3-axis router?  (Read 20378 times)
Hello, I am new to the forum and also to using Mach3. I recently undertook the task of setting up a 3-axis K2 router equipped with servos and new Geckodrives G320X. I am having trouble setting up mach and getting it to communicate with the servos. The drives were previously installed by someone else and I dont know which ports and pins to designate on Mach. Does anyone have a complete rundown or tutorial to set up something like this? I am basically starting from scratch here and dont have a clue as to what to do. Any info would be much appreciated.
Offline TPS
  •  2,627 2,627
Pictures, Pictures, Pictures.
Offline ZASto
  •  434 434
Which controller are you using?
As tps wrote, some *********ography please :D
My personality is who I am.
I’ll get some pics up right now.
Need help! K2 router problems!
« Reply #4 on: September 15, 2020, 12:36:45 PM »
Does anyone know what breakout board comes in the K2 router control box?? Im trying to configure mach3's ports and pins and I have no clue what my inputs and outputs are. Ive tried contacting K2, they seem to be out of business. I really need to know what breakout board they used. The control box has gecko drives G320X's and the router has servos on all 3 axis. What should I do and where should I start?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Need help! K2 router problems!
« Reply #5 on: September 15, 2020, 04:15:06 PM »
Lots of pictures for us to asses first.
having trouble uploading my photos... However I have another question. The PC that was previously running mach3 for this router crashed and lost all the configuration settings. Would downloading Mach3 on another PC automatically configure my settings for this router? Like the Ports/pins?
Offline TPS
  •  2,627 2,627
is itrealy so hard to to click the  "Attachment and other Options" Botton?
NO all the configurations are stored in one file, called "C:Mach3\your profilename.xml"
BTW: all our completly unimportant questions about further detailed informations have not been answered.
First off idk what a "botton" is. Secondly, every time I attach photos and click post nothing happens. Photos are the correct size and format.
1
