Hello Guest it is September 06, 2026, 12:09:50 AM
Author Topic: Pins and Ports for Fireball V90  (Read 29687 times)
  •  9,368 9,368
Re: Pins and Ports for Fireball V90
« Reply #10 on: September 15, 2020, 12:16:06 AM »
From your last picture you have a CNC USB Motion Controller. This operates with the Planet-CNC software and does not require the use of Mach3.
I am currently unable to reach the new Planet CNC website but you should be able to download the necessary software and manuals from their old site here;
http://old.planet-cnc.com/index.php?page=download
EDIT;  The Planet CNC site is back up again & you can download from here; https://planet-cnc.com/software/
« Last Edit: September 15, 2020, 05:18:08 AM by Tweakie.CNC »
« Reply #11 on: September 15, 2020, 09:28:44 AM »
Thank u for the suggestion I downloaded it and still cant move machine at all. I already have Mach3 USB style motion controller on my Langmuir Systems CNC plasma cutter and works just fine after I put in correct pins ports and motor values. Please can someone tell me correct Pins Ports and Motor values to plug into Mach3 to make my machine move I can take it from there on tuning just don't know Values and check marks to plug in to get started.
« Reply #12 on: September 15, 2020, 09:32:00 AM »
Fireball v90
« Reply #13 on: September 15, 2020, 09:32:40 AM »
Here is machine.
« Reply #14 on: September 15, 2020, 01:13:08 PM »
When I try using the PlanetCNC software it keeps saying no controller found even if I hook up my Langmuir Systems Contoller to it which I know works on Mach3 all day everyday. Someone Please Help??????
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #15 on: September 15, 2020, 04:12:03 PM »
You will need a Mach3 plugin for that to be possible and I don't think they do one.
Your other option is a new breakout board or motion controller.
  •  9,368 9,368
« Reply #16 on: September 16, 2020, 12:23:48 AM »
Unfortunately it is not quite as simple as that...
Your CNC-USB motion controller has to interpret the data which is sent in packets via the USB connection and currently it will not recognize Mach3 (irrespective of the Mach3 Ports & Pins settings).
You could try contacting Planet-CNC to ask if they have a suitable plug-in for your particular motion controller.
Offline TPS
  •  2,627 2,627
« Reply #17 on: September 16, 2020, 01:29:28 AM »
had a quick look to at the planet-cnc webside. does not look like they Support a Mach3 pluging for the Controller. So only Chance will be to swap the USB Controller.
also this post here: http://forum.planet-cnc.com/viewtopic.php?f=2&t=2473
says that mach3 is not supported.
« Reply #18 on: September 16, 2020, 10:59:19 AM »
Mach3 is not type of controller it is the software I paid $175 for to run my plasma cutter and anything else cnc I wanted to operate so anybody have any suggestions on good cheap motion controller I can buy to run this equipment. Is the box messed up or why can’t Mach3 talk to it???
Offline TPS
  •  2,627 2,627
« Reply #19 on: September 16, 2020, 02:30:46 PM »
WE KNOW THAT AND, WE ARE TRYING TO MAKE YOU THIS TO UNDRSTAND
BECAUSE IT WAS NEVER DESIGNED TO TALK TO IT.
see my reply#18
LOOKS LIKE YOU DO NOT EVEN READ THE ANSWERES, MAY ALSO DEPEND ON MY BAD BAVARIAN ENGLISH.
« Last Edit: September 16, 2020, 02:40:02 PM by TPS »
