Hello Guest it is November 03, 2026, 12:41:26 PM
Author Topic: When pushing left arrow X axis goes right  (Read 15166 times)
« on: August 06, 2020, 05:59:43 PM »
Greetings.  This is my first post. I am very new to this.
I have homed in the coordinates on my limit switches which are in the lower left as facing the machine, and the X axis coordinates are also backward on the screen, just for the X axis.  The X axis moves the opposite of the arrow buttons.
I would appreciate and thank you ahead of time for any help.
Re: When pushing left arrow X axis goes right
« Reply #1 on: August 06, 2020, 08:51:22 PM »
Let me clarify.  If I have my X axis all the way to my left, and zero it out, if I want to move to the right I have to push the left arrow key.  And the DRO gets larger as it moves right, but is identified as a negative number.
« Reply #2 on: August 06, 2020, 11:17:36 PM »
BTW, I am the owner of genuine Mach 3 software I purchased here.  I'm running the CNC with NVUM controllers.
  •  9,375 9,375
« Reply #3 on: August 07, 2020, 12:45:11 AM »
In Config, / Ports & Pins / Motor Outputs  change the 'Dir Low Active' state for your X axis.
Please note, the forum does not provide support for Novusun products, this thread refers;  https://www.machsupport.com/forum/index.php?topic=24331.0
« Reply #4 on: August 07, 2020, 09:42:25 AM »
You da man.  Thank you!
