Hello Guest it is October 24, 2026, 02:37:40 AM
Author Topic: Are G33 & G76 supported in Mach3?  (Read 13038 times)
Offline JG
  •  66 66
« on: July 17, 2020, 02:49:56 AM »
I'm investigating 'Thread Milling' but cannot find any details about the parameters I need to add after a G33 or G76 call. Using the [ G-Code ] button in Mach3, these codes are not listed so there are no 'hints' and I can't make head nor tail of what is supposed to happen after I select the 'Thread Milling' Wizard -- it simply shows me a new screen with Exit. Post Code, etc. along with a number of apparently editable dimensions which return to the initial state upon exit. The [ Post Code ] does not alter the 'No File Loaded' message.
Since I am looking to make 'large' (but short) threads  -  100 - 200mm dia and 2 - 4.5mm pitch  -  using a single point tool a 'Tap' is not an option  :)
I understand the complexity of threads needing a very specific feed rate in the Z axis which will not (necessarily) be the same as the feed rate in X & Y but cannot yet see any G-Code that will achieve that.
Any input appreciated!
Offline TPS
  •  2,627 2,627
Re: Are G33 & G76 supported in Mach3?
« Reply #1 on: July 17, 2020, 03:42:37 AM »
Offline JG
  •  66 66
« Reply #2 on: July 17, 2020, 03:54:11 AM »
Thanks for the input TPS but that is about Mach3TURN  I'm looking for a solution for Mach3Mill  - sorry I should have made that clear in my post  :-[
Offline TPS
  •  2,627 2,627
« Reply #3 on: July 17, 2020, 03:58:24 AM »
for thread milling i am using a cam Programm called Estlcam.
it is cheap and easy to handle, also for other parts to create cnc code.
https://estlcam.de/
sorry the side is in German, but the Software can be switched to english.
Offline TPS
  •  2,627 2,627
« Reply #4 on: July 17, 2020, 04:03:43 AM »
here:
https://www.youtube.com/watch?v=xO-GHEIIOQQ
is a Video, where he demonstrates how it works.
Offline JG
  •  66 66
« Reply #5 on: July 17, 2020, 04:22:06 AM »
Thanks, I'd already found that video and watched it before your re-post came in  :)
It looks to do the business - though that video only shows 'Standard' threads, I'm sure 'specials' are also catered for.
What it doesn't tell me is what parameters I need to enter when writing G-Code by hand.  Yes I am a masochist!   ;D
Offline TPS
  •  2,627 2,627
« Reply #6 on: July 17, 2020, 04:27:51 AM »
i am affraid G76 will only work on in turn mode, but i am not a specialist.
Offline JG
  •  66 66
« Reply #7 on: July 17, 2020, 04:37:45 AM »
Is that as far as Mach3 is concerned?
I see G76 listed as also available as 'Fine Boring Cycle for Milling' which seems to suggest that the Z feed can also be specified as a separate parameter.  It also 'Includes OSS and shift (oriented spindle stop and shift tool off centerline for retraction)'  -  I just can't find any reference to the form that the parameters take.
