Hello Guest it is October 23, 2026, 07:16:23 PM
Author Topic: G82 Drilling Cycle  (Read 27621 times)
Offline TPS
  •  2,627 2,627
Re: G82 Drilling Cycle
« Reply #10 on: July 15, 2020, 04:30:51 AM »
in your main Folder (noramly c:\Mach3) should be a file named:
Mach3MillGcode.htm
this file contains the G-Code help and can also be opened with any browser.
Offline JG
  •  66 66
« Reply #11 on: July 15, 2020, 05:19:52 AM »
Thanks TPS -- yes that file exists in both of my systems and I now have a shortcut to it on my office system.
It is still not activated by the [ G-Code ] button - whichever '.set' I invoke.
I'm not concerned about trying to resolve the issue - it's no hardship to simply invoke the shortcut which opens the .htm file in the browser when I do need a 'hint'   -   which I'm sure will be often  ;D
  •  9,374 9,374
« Reply #12 on: July 15, 2020, 05:39:51 AM »
If it's any help,   Operator / Edit Button Script allows the G-Codes button code to be changed as shown in this pic.
Offline JG
  •  66 66
« Reply #13 on: July 15, 2020, 05:59:14 AM »
Thanks Tweakie,  That at least points me to yet another 'feature' in the very flexible Mach3 system which I hadn't yet discovered but the VB script in my office system is already exactly as you site - I presume my workshop system is the same.
Seldom taking anything on face value  -   I've just clicked on the [ Run Script ] icon and I'm not surprised to see an error message  "Error on line:1 - Sub or function not defined: GetMainFolder"   but since I am yet to study VB it doesn't really tell me much.
  •  9,374 9,374
« Reply #14 on: July 15, 2020, 06:09:25 AM »
I think you have something else wrong in your Mach3 installation (could be anything and short of a re-install I have no idea where to look).
Offline JG
  •  66 66
« Reply #15 on: July 15, 2020, 06:18:10 AM »
That's my opinion as well Tweakie.
Since the 'office' system is only a simulation exercise, a re-installation wouldn't be a problem and may well solve the issue.
Offline JG
  •  66 66
« Reply #16 on: July 21, 2020, 05:52:21 AM »
I've been held up in this endeavour due to slow delivery of components but they arrived yesterday so I'm back on it.
When trying a simulation (cutting air) on my workshop system I had a 'Soft limits error' --- which I think I've solved  ---  but when investigating I came up against another 'irritation' in Mach3 regarding the [ Table Display ]  window.  I can 'Zoom' and move the display 'in orbit' OK (even turning the whole thing upside down) but I can't yet see a way to re-position the viewpoint - which effectively means 'panning'. I'm familiar with similar displays in SketchUp etc. where panning is a matter of 'shift' if you are in 'Orbit' but none of the modification keys ( Ctrl etc.) seem to have any effect. Nor does [ Display Mode ] appear to do anything, which might have been an option.
It must surely be my lack of experience with Mach3 controls but I've yet to find anything intuitive that works to modify the display - nor anything in the 'help' to point me to a solution  :(
Can someone enlighten me ?
  •  9,374 9,374
« Reply #17 on: July 21, 2020, 07:23:02 AM »
Right click and drag ?
Offline JG
  •  66 66
« Reply #18 on: July 21, 2020, 07:52:14 AM »
No  -  that is what I've been doing and it 'Orbits' quite correctly (as I would expect)  but doesn't change the 'Centre of Rotation' which is what 'Panning' ought to do.
I've also tried zooming out and then clicking to the right or left of the image to zoom in about that point - without success.
Offline JG
  •  66 66
« Reply #19 on: July 25, 2020, 01:44:42 PM »
Thought you might like to know that I've found the answer to this issue.   It's all about settings in [Config][Tool Paths]. Once I'd found that I had much more control and could decide for myself how I wanted the Tool Paths Window to look.
It's not perfect, and I'll do some more experimenting, but much better that the view I was getting by default.
