Hello Guest it is November 22, 2026, 02:37:13 PM
Author Topic: Motors Not Turning But Are On  (Read 24137 times)
Re: Motors Not Turning But Are On
« Reply #10 on: July 13, 2020, 01:37:53 AM »
I checked the jumpers on the C11G board but maybe I got them wrong on the ESS itself? That's the last thing I didn't really check that I can think of atm.
Offline TPS
  •  2,627 2,627
« Reply #11 on: July 13, 2020, 01:41:37 AM »
have you set the enable on the c11g?
« Reply #12 on: July 13, 2020, 01:46:48 AM »
I'm a little confused by that diagram. Are you referring to the jumper by the 5v input? If so that's currently set to ground...
Sorry again for my ignorance. As you can tell I'm quite new at this.
« Reply #13 on: July 13, 2020, 01:53:59 AM »
If you're asking if I put a 5v power supply there, I did. The red wire goes to the +5v, a second wire goes from the +5v to the enable, and the black wire goes to the ground.
Offline TPS
  •  2,627 2,627
« Reply #14 on: July 13, 2020, 02:07:19 AM »
the 5v supply Need to go to the power terminals.
the enable Needs to be bridged with a wire like on the Picture or has to be supplied by macropump.
all this is explained inthe Manual:
http://cnc4pc.com/Tech_Docs/C11G-R9_USER_MANUAL.pdf
« Reply #15 on: July 13, 2020, 09:22:48 AM »
Yeah, I wired it as shown on this page (obviously with different drivers and motors).
https://www.ebay.com/itm/6-Axis-USB-MOTION-CONTROLLER-UC100-for-Mach3-with-Relay-and-Spindle-Control-C11G-/163811326503
