Third party software and hardware support forums. > Newfangled Mill Wizard
Can I add to the Tool Library??
(1/1)
joeaverage:
I use MillWizard alsmost daily, its so handy for doing small jobs.
I use 0.5mm, 0.8mm and 1.5mm endmils alot. The 0.8mm and 1.5mm are four flute and the 0.5mm
are two flute.
When I go to do a new job you have to select the tool but none of these endmills occurr in the tool library.
I've not found a way to include my go-to tools in the library. Is there some technique or manipulation that I'm
missing?
Graham Waterworth:
The tool table is in the config menu
joeaverage:
kool, thankyou.
Navigation
[0] Message Index
Go to full version
