Hello Guest it is October 25, 2026, 02:04:00 PM
Author Topic: z after running file  (Read 40311 times)
Re: z after running file
« Reply #10 on: September 30, 2007, 07:51:52 PM »
Yo Fellas,  Excuse me if this sounds obvious but, have you checked the "Safe Z setup" in the config menu?  You can make your safe Z reference to machine coords OR work coords.  If you are referenced to work coords and your work offsets change from job to job then so will your safe z.  Hopefully that made sense, if not, it will when you look at the safe z setup screen.
HTH,
Sid
« Reply #11 on: September 30, 2007, 09:59:00 PM »
Sid, The problem is happening even when I run the same part over and over with no offset change. I checked the safe Z settings. I was able to make it better by setting it to incremental rise. Now it only changes things the first time I hit the rewind button. After that it seems to be all right. I was playing with the settings with the mill offline. I will try it with the mill running in a day or 2.
Thanks all for or help
Mark
« Reply #12 on: September 30, 2007, 10:26:00 PM »
Are you using a stepper or a servo for your Z axis?
« Reply #13 on: September 30, 2007, 11:40:44 PM »
Stepper
vmax549
« Reply #14 on: October 01, 2007, 06:50:28 AM »
There was a problem starting with V2.42 that envolved the stop , rewind, regen functions that could cause a dro reset. It was fixed at version 2.50. Try the upgrade first to see if it goes away.
« Reply #15 on: October 01, 2007, 09:48:06 AM »
I agree w/ Vmax, try the update first but, I kinda also think it sounds like you are missing steps on your down cuts.  That would explain why Z is raising up higher in a random way.
Sid
« Reply #16 on: October 01, 2007, 09:08:26 PM »
I went back to version 2.065 and the problem went away.
Vmax twice you suggested upgrading to version 2.50. Were do I get version 2.50? Is it a future release?
Mark
« Reply #17 on: October 01, 2007, 09:59:49 PM »
It is in the downloads section, 2.52 now.  :) Below the lock down versions. See where the cursor is pointing to in the screen shot.
« Last Edit: October 01, 2007, 10:01:51 PM by Chaoticone »
« Reply #18 on: October 01, 2007, 10:42:36 PM »
Thank You!!
Mark
vmax549
« Reply #19 on: October 02, 2007, 06:44:57 AM »
Sorry Guys, Art used to label the updates, I guess he stopped doing it. I will pay more attention in the future.
