Hello Guest it is November 05, 2026, 09:28:24 PM
Author Topic: write wizard  (Read 115636 times)
write wizard
« on: May 28, 2020, 06:47:49 PM »
I can use the write wizard to engrave but when I save the .tap file and load it again, it put a bunch of circles in the cut. I am renaming the default "write.tap" file so I can find it again. It seams to be adding lines of code. I would like to not have to rewrite every time.
  •  9,375 9,375
Re: write wizard
« Reply #1 on: May 29, 2020, 12:05:11 AM »
To remove the 'crop circles' change the IJ Mode (Config. / General Config.).
(Ideally all Gcode files using arcs should contain the G90.1 / G91.1 as appropriate).
