Hello Guest it is November 24, 2026, 01:13:55 AM
Author Topic: Need idea for timed oiler  (Read 9305 times)
Offline Jackal
  •  173 173
« on: May 25, 2020, 09:16:56 PM »
I haven't messed with my Mach 3 in a while.
There is an auto oiler, that is operated by a slow geared drive and contacts.
About every 20 minutes, it clicks on, and oils for 7 seconds????????
  I have an override button on the control panel that I hit during startup and when homing everything.
    Would I need to program a brain for something like that?
 Can you direct me to where I can find info on this.
Thanks a lot.
Everything is bio-degradable if you run over it enough with a lawnmower.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Need idea for timed oiler
« Reply #1 on: May 27, 2020, 07:22:04 PM »
You can add code to the Macropump.m1s to turn it on and off.  Then you need to enable the macropump in config.
Offline Jackal
  •  173 173
« Reply #2 on: May 28, 2020, 09:22:03 AM »
Ok. Thanks. Do you have a link where I can find out more info?
I'll start researching that now.
Thanks again
Offline Jackal
  •  173 173
« Reply #3 on: May 28, 2020, 09:56:21 AM »
I just found some pump macros already written.
Thabks again
