Hello Guest it is November 22, 2026, 09:12:00 AM
Author Topic: Adding more inputs or outputs to Mach3  (Read 35115 times)
Re: Adding more inputs or outputs to Mach3
« Reply #10 on: May 08, 2020, 03:58:44 AM »
Sorry I mean variable type not modifier. :-[
« Reply #11 on: May 08, 2020, 04:19:02 AM »
Here is the CDIO.DLL file and the CDIO Help file I found if you want to have a try.
Cheers,
Mark
Offline TPS
  •  2,627 2,627
« Reply #12 on: May 09, 2020, 01:25:20 AM »
i think the Problem is that the variable Id is not specified
try a
Id = 0 at the begin of code
« Reply #13 on: May 09, 2020, 03:34:59 AM »
Hi TPS,
Yes i had tried that but with no luck. I have also done "dim Id as Integer" And I have changed the short to integer and to many other data types.
Mach3 talks to the cards fine in the Pins and ports setup and i can operate as many I/O as listed in the setup.
The PCI cards are listed as Port3 And Port4 in Mach3. so if i set Mach3 OUTPUT1 to Port3 pin1 then the card will output the pin1 on the first card.  Can i link OEM buttons or LEDs to Mach3 ports and pins without the OUTPUT1 command.
ie   OEMLED1 = port3.pin2 or something like that??
Cheers,
Mark
Offline TPS
  •  2,627 2,627
« Reply #14 on: May 09, 2020, 04:49:53 AM »
so if you are able to Access the Card via the regular port/pin Setup, they should be also be red/writeable via
GetPortByte(PortAddr)
and
PutPortByte(PortAddr)
as shown in this example i did
Code: [Select]
  ' Our port address
  PortAddr = 1016 ' 0x3f8
  ' Read data register of parallel port at 0x3f8
  PortData = GetPortByte(PortAddr)
  ' write the data to OEMLed's
  SetUserLed(2001,PortData And &H01)
  SetUserLed(2002,PortData And &H02)
  SetUserLed(2003,PortData And &H04)
  SetUserLed(2004,PortData And &H08)
  SetUserLed(2005,PortData And &H10)
  SetUserLed(2006,PortData And &H20)
  SetUserLed(2007,PortData And &H40)
  SetUserLed(2008,PortData And &H80)
you have to out in there the same port adress as in Mach3 setup
Offline TPS
  •  2,627 2,627
« Reply #15 on: May 09, 2020, 04:58:07 AM »
example to write UserLed's to a port
Code: [Select]
'example to write UserLed 2201-2208 to port
'Our port address
PortAddr = 1016 '0x3f8
PortData = 0
If (GetUserled(2201) = 1) Then
  PortData = PortDate + 1
End If
If (GetUserled(2202) = 1) Then
  PortData = PortDate + 2
End If
If (GetUserled(2203) = 1) Then
  PortData = PortDate + 4
End If
If (GetUserled(2204) = 1) Then
  PortData = PortDate + 8
End If
If (GetUserled(2205) = 1) Then
  PortData = PortDate + 16
End If
If (GetUserled(2206) = 1) Then
  PortData = PortDate + 32
End If
If (GetUserled(2207) = 1) Then
  PortData = PortDate + 64
End If
If (GetUserled(2208) = 1) Then
  PortData = PortDate + 128
End If
PortData = PutPortByte(PortAddr, PortData)
« Reply #16 on: May 09, 2020, 05:08:52 AM »
The cards are running through a Mach3 plugin to allow Mach3 to see them.
The port address in windows hardware manager are E480 for one card and E800 for the other card.
I tried these values with no success.
I think its only readable because of the plugin but dont really know. there is basically no information about the plugin but it allows for up to 4 cards so they must have made it to run over 100 odd inputs or outputs, i just do not know how to access them. There must be a way.
Cheers,
mark
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #17 on: May 09, 2020, 06:39:00 AM »
I think the port get and put only work with the parallel port driver loaded.
Offline TPS
  •  2,627 2,627
« Reply #18 on: May 09, 2020, 11:58:56 AM »
do you have some more Information about the  Cards and the plugin?
there must be way to get Access to These in- Outputs.
because, if the plugin get Access there must be a way to get access.
 the plugin must reflect These IOs to somewhere,i think into modbus IO aeria, like all the other
Motion Controller do it.
« Reply #19 on: May 09, 2020, 08:01:18 PM »
The plugin is on the downloads page of mach3 website and the documentation is there also. there is even a forum like here too which ive also asked in but no response form anyone. The plugin is CONTEC. I have two CONTEC PIO-16/16T(PCI) cards in the computer. they are hooked to the tool changer and work perfectly in camsoft. Mach3 works with both cards when setting the ports/pins to OUTPUT#
I have attached all the info and some sample programs that came with the DLL file. You maybe able to make sense of it.
Cheers,
Mark
