Hello Guest it is October 22, 2026, 10:31:20 PM
Author Topic: M6 not updating Current Tool info.  (Read 5933 times)
« on: April 26, 2020, 03:10:40 PM »
This topic has been beaten to death, but for the life of me I can't seem to fix this problem. On T5 M6 (where T on M6 line is tool to use), the tool number in the Current Tool Information box does not change. Actually, it doesn't change either if I switch T to be next tool. The problem persists whether I use upper or lower case M. Here's the standard script from the editor.
When I enter a G43 H5 command, the H offset changes correctly to Tool #5's, but the tool number is stuck at my touch off tool.
What's missing?
Joe
function m6()
   local selectedtool = mc.mcToolGetSelected(inst)
   local currenttool = mc.mcToolGetCurrent(inst)
   if selectedtool == currenttool then
      mc.mcCntlSetLastError(inst, "Current tool == Selected tool so there is nothing to do")
   else
      --Remove this line if you would not like the Z axis to move
      --mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z0.0");--Move the Z axis all the way up
      mc.mcCntlToolChangeManual(inst, true);
      mc.mcCntlSetLastError(inst, "Current tool == " .. tostring(selectedtool) .. "   Previous Tool == " .. tostring(currenttool))
      mc.mcToolSetCurrent(inst, selectedtool)
   end
end
 m6()
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: M6 not updating Current Tool info.
« Reply #1 on: April 26, 2020, 05:44:19 PM »
Lathe or mill?
« Reply #2 on: April 26, 2020, 07:00:01 PM »
Hi Graham,
This is for a mill.
Joe
