Hello Guest it is September 30, 2026, 12:00:10 AM
Author Topic: Turn tool turret macro  (Read 63560 times)
Offline TPS
  •  2,627 2,627
Re: Turn tool turret macro
« Reply #10 on: April 21, 2020, 07:05:19 AM »
what have you selected in Config -> General Config -> Toolchange?
« Reply #11 on: April 21, 2020, 10:34:19 AM »
Thanks both, I will try those pointers shortly as I think my motion controller plugin is causing other issues when its not connected and i'm still trying to run mach. I will update on my findings  ;)
« Reply #12 on: April 22, 2020, 08:47:20 AM »
Ok, an update  ;D
So I have added in some small sleep commands into my code to allow the dro to update, also added in the msgbox to see if M6 was actually being called. Long story short, I have ended up with the turret working correctly and the M6Start macro doing what it should.
One small shameful confession, the tool change was set to ignore in the general config screen, which had made life very difficult. However, this must have happened during a crash (as mach3 frequently does on my laptop) because this setting was set to auto tool changer prior to my first post in this thread. Stoopid mistake I know... but I never thought to check this as I'd already set it to atc!! Oh well, its all working great now  :D :D
Thanks all for your assistance
« Reply #13 on: April 23, 2020, 04:17:03 AM »
I spoke too soon!
I do have some problems with my code in the M6Start macro.....
I think the problem is with the while loop in the DoToolChange() sub.
What the code is supposed to do is:
- Check the tool number is valid, if its allowed proceed to DoToolChange()
-The tool number is sent to a PLC via modbus, that is giving a tool change allowed signal (INPUT1), but is waiting for the command to change the tool from mach (OUTPUT6).
-Once (OUTPUT6) goes high, the PLC sends (INPUT1) low while it cycles the tool. Once it has successfully located and locked the tool, it will set (INPUT1) high again. If it doesn't, something has gone wrong.
-The While loop is supposed to look at when (INPUT1) is low and wait for it to go high again, before it calls ToolComplete(), it should also start timing 4 seconds, by which time if it hasn't seen the signal it will call ToolFailed().
The while loop is doing something strange and won't go to either ToolComplete() or ToolFailed(), I think its something to do with the timer, but cant quite figure it out.
If anyone wouldn't mind looking over my code to see if anything jumps out please?
Code: [Select]
'CYCLONE - Auto tool changer (8 pos turret type)
'V1.0
'CONFIG
NewTool = GetSelectedTool() 'Commanded tool number
OldTool = GetCurrentTool() 'Current tool number
MaxToolNum = 8 'Max number of tools for the changer
PreviousSpeed = GetRPM() '
ToolSpeed = 500
'MACRO START
DeActivateSignal(OUTPUT6) 'Make sure signal to PLC is negative
code"G91 G28 Z0" 'set incremental, return home via X first
SetSpinSpeed(ToolSpeed) 'Spindle speed change
While IsMoving()
Wend
While NewTool > MaxToolNum 'Dont allow tool number greater 8
Message("MAX TOOL NUMBER = 8")
Wend
While NewTool < 0 'Dont allow tool number less than 1
Message("INVALID TOOL NUMBER")
Wend
If NewTool = OldTool Then
Call ToolComplete
Else
If IsActive(INPUT1) Then 'ok signal from PLC
Call DoToolChange
Else
Message("TURRET NOT READY!")
End If
End If
End
'TOOL CHANGE
Sub DoToolChange()
SetCurrentTool(NewTool) 'Update the tool DRO
Call ActivateSignal(OUTPUT6) 'Set tool change allowed signal to PLC
SetTimer(1)
sleep 200
t = GetTimer(1)
While IsActive(INPUT1) = False 'While the turret is moving, count down
If IsActive(INPUT1) = True Then 'If input goes high again, tool has cycled
Call ToolComplete
'Else
If t > 4000 Then
Call ToolFailed
End If
End If
sleep 100
Wend
'End If
End Sub
'TOOL COMPLETE
Sub ToolComplete()
SetSpinSpeed(PreviousSpeed) 'RPM before tool change called
sleep 100
End Sub
'TOOL FAILED
Sub ToolFailed()
f = 1
While f = 1
Message("TURRET TIMEOUT")
Wend
End Sub
Offline TPS
  •  2,627 2,627
« Reply #14 on: April 23, 2020, 04:46:07 AM »
i think that is what you try to do
Code: [Select]
'Clear timer 1
SetTimer(1)
t = GetTimer(1)
If t > 4000 Then
Call ToolFailed
End If
Sleep 100
Wend
Call ToolComplete
« Reply #15 on: April 23, 2020, 07:25:16 AM »
Ahh..., Ok I'll try this asap!
« Reply #16 on: April 24, 2020, 03:35:02 AM »
Had a chance to try this, this morning.
The While loop now works and unless it sees (INPUT1) it will not exit the loop.
The timer however does not work. I have tested the timer by sending a message when ToolComplete() is called and it always returns zero.
I've changed the timer number and also changed where SetTimer() is in the macro, but it only ever returns zero, is there a way it needs to be started?
Code: [Select]
'TOOL CHANGE
Sub DoToolChange()
'Call ActivateSignal(OUTPUT6) 'Set tool change allowed signal to PLC
SetTimer(20) 'Clear timer 1
sleep 500
t = GetTimer(20)
If t > 4000 Then
Call ToolFailed
End If
Sleep 100
Wend
Call ToolComplete
End Sub
'TOOL COMPLETE
Sub ToolComplete()
Message("Tool Change Complete in " & GetTimer(20) & " seconds")
sleep 100
End Sub
Offline TPS
  •  2,627 2,627
« Reply #17 on: April 24, 2020, 05:21:30 AM »
did some tests Looks like the Timer Resolution is 10 seconds this code should work better
Code: [Select]
'TOOL CHANGE
Sub DoToolChange()
sleep 500
While NOT IsActive(INPUT1)  'While the turret is moving, count down
t = GetTimer(20)
If t > 0.4 Then
Call ToolFailed
End If
Sleep 100
Wend
Call ToolComplete
End Sub
'TOOL COMPLETE
Sub ToolComplete()
sleep 100
End Sub
« Reply #18 on: April 24, 2020, 07:58:19 AM »
Thanks for testing this, Will give it a try later  ;)
« Reply #19 on: April 24, 2020, 08:52:55 AM »
GetTimer() still returns zero...
Code: [Select]
SetTimer(1)
sleep 1000
MsgBox(GetTimer(1))
This should say 1000ms right? or 0.1 if the timer resolution is 10 seconds? I just get 0
