Hello Guest it is April 19, 2024, 05:58:38 AM
Author Topic: Probing from the same place  (Read 2137 times)
« on: April 02, 2020, 12:30:38 PM »
Hi.
Probably the 100 person who asks this  ;D ;)
Trying to find any information or ready g-code, macro?
I want a fixed place on the machine where the tool is measuring from all the time. So need an easy guide to this as I am brand new to this hobby, and don't want to guess anything so something breaks.
Grateful for all the help I can get 8) :)
Re: Probing from the same place
« Reply #1 on: April 02, 2020, 12:54:38 PM »
Clarification
In short, I want to be able to:
1. Mount the tool in the home position.
2. Press Auto tool zero, the machine automatically goes to fixed point and performs measurement.
3. The machine either returns home or is left waiting for orders after the completed measurement
It is a button I will use so I do not have to mount clips etc on the tool during the measurement
Offline TPS
  •  2,505 2,505
« Reply #2 on: April 03, 2020, 09:28:55 AM »
to do this your machine will Need home Switches, so that it can be referenced, because a fixed Position will allways be
in machine coords.the rest is easy.
« Reply #3 on: April 03, 2020, 10:42:47 AM »
My machine already has home switches.
I found this script online that I tested in Mach3 (demo).
But I only want to use it in metric. So do not know where I change the value for it to suit me.
Dim Zprobe, Zretract, ZfeedRate
Dim PlateX, PlateY
'Note: TouchPlateHeight represents the actual height of the
' Auto Z Touch Plate from the work surface.
' Minor adjustments can be made for calibration purposes (use caution)
TouchPlateHeight = .089        <<--- values ​​in metric??
Message( "Auto Tool Zeroing..." )
If IsSuchSignal (22) Then
isMetric = GetOEMLED(801)
Zprobe = -3
Zretract = 1.5
ZfeedRate = 10
PlateX = 10                                    <<-- I guess this value needs to be changed to fit my machine?
PlateY = 10                                  <<-- I guess this value needs to be changed to fit my machine??
If isMetric = 0 Then
Zprobe = Zprobe * 25.4
Zretract = Zretract * 25.4
ZfeedRate = ZfeedRate *25.4
TouchPlateHeight = TouchPlateHeight * 25.4
PlateX = PlateX * 25.4
PlateY = PlateY * 25.4
End If
Code "G53 G0 X" & PlateX & " Y" & PlateY
Call SetDRO( 2, 0.00 )
code "G31 Z" & Zprobe & " F" & ZfeedRate
While IsMoving()
Wend
Call SetDRO( 2, TouchPlateHeight )
code "G1 Z" & Zretract
End If
Is there any other script, g-code that is more suitable for me?
Don't know anything about programming otherwise I could have figured this out
Offline TPS
  •  2,505 2,505
« Reply #4 on: April 04, 2020, 03:07:35 AM »
if have cleared up the code a Little bit and made some safety checks
Code: [Select]
Sub Main()
Dim PlateX, PlateY
'set all parameters in metric
TouchPlateHeight = 30
Zprobe = -50
Zretract = 20
ZfeedRate = 10
PlateX = 10
PlateY = 10
'check probe allready active
If GetOEMLed(825) Then
MSGBox "Probe allready activ",vbOK + vbCritical ,"Fault !"
DoButton(21)
End
End If
' go to probe position
'clear z-pos
'do the probing
While IsMoving()
Wend
'test for max trave
If GetVar(2002) <= Zprobe + 0.5 Then
MsgBox "no probe hit!",vbOK + vbCritical ,"Fault !"
End
Else
'move to contact point due overrun
Code "G90 G0 Z" &GetVar(2002)
While IsMoving()
Wend
'set z axis height
'go to retract position
code "G1 Z" & Zretract & "F20"
End If
'clear status line
Message " "
End Sub
it is not tested, just written down.
but i think in your case it will not do what you want to do, but you can test it and see.
this code will set the z-axis Zero allways to the top of your measuring knob, but i guess you want
to set it to your actual workpiece surface.
Offline ZASto
  •  423 423
« Reply #5 on: April 04, 2020, 04:50:43 AM »
In the attached file is what I use on my machine. One moveable plate for setting material Z0 and one fixed plate for all subsequent tools.
These codes are associated with two buttons in screenset that I use (by BlueTex, modified to suit my needs)
My personality is who I am.
« Reply #6 on: April 04, 2020, 10:53:58 AM »
Thanks so much.
I'll test these  :) :D
