Hello Guest it is November 22, 2026, 07:29:15 PM
Author Topic: homing issues  (Read 8661 times)
homing issues
« on: March 13, 2020, 11:23:50 AM »
I am running mach 3 connected to a machine with a Gecko g540. For limit switches I am using cnc router parts proximity swiches.
The machine has been up and running for about 18 months without any major issues. Homing and limit switches were working fine until about 3 weeks ago. At that time when I would home the machine the y axis would home properly but the x axis would move to the limit switch, trip the switch but not back off to a home position. I have checked the configuration and it has not changed.
Any idea what could cause this issue? I have an extra proximity switch that I could change out, but it seems that something changed elsewhere due to the fact that the limit switch will trip.
Thanks.
BG
Offline TPS
  •  2,627 2,627
Re: homing issues
« Reply #1 on: March 13, 2020, 01:24:56 PM »
sounds lik Windows update isue.
Re: homing issues
« Reply #2 on: March 13, 2020, 01:39:18 PM »
That is not it, machine is not connected to the internet at all.
Thank you for the input.
BG
Re: homing issues
« Reply #3 on: March 17, 2020, 11:00:41 PM »
This has been resolved.
I had another machine profile that I tested the "ref all home" button. That button worked properly so I loaded and copied the vbscript from that profile to the defective profile.
I am not really certain what was defective in the vbscript, because they had the same code, but copying the code did work.
Thanks!
BG
