Hello Guest it is November 13, 2026, 08:09:37 PM
Author Topic: Index  (Read 45937 times)
Re: Index
« Reply #30 on: March 17, 2020, 05:44:25 AM »
Getting closer (I think).
Cleaned the device and now it seems to work. Wired it up to the the mill for a test(not installed). The green light on the hardware page responds with on and off. The same does the red status LED on the BOB (G11G Multifunction CNC board Rev. 9 from CNC4pc).- but Mach3 vil not show the REW, the display just flicks wildly even if no a speed is called for.
For ref. my setup is:  Windows 10, Mach3, Smooth Stepper ver. 1.2,  BOB as above and the mill is a SIEG KX3 CNC Mill
« Last Edit: March 17, 2020, 05:46:20 AM by sivtek »
Re: Index
« Reply #31 on: March 24, 2020, 12:38:15 PM »
Can some tell me why the rev. counter in Mach3 doesn't register the RPM even as the signal is showing up in the hardware page? (Index botten get activated - on and off).
The optho switch is working nice thanks to MN300 and is giving .6 volt and 4.7 volt when reflected and non reflected.
Offline TPS
  •  2,627 2,627
Re: Index
« Reply #32 on: March 24, 2020, 01:41:35 PM »
see
Re: Index
« Reply #33 on: March 25, 2020, 06:06:44 AM »
Thanks TPS your reply, but it bid not help, no indications of RPM on the screen. The green index light on the Mach3 screen is active and also a red LED light on the BOB indicating that the input signal is active.
Re: Index
« Reply #34 on: March 26, 2020, 04:27:10 AM »
Is there somewhere I can get information and help to solve my problem?
Offline TPS
  •  2,627 2,627
Re: Index
« Reply #35 on: March 26, 2020, 04:36:49 AM »
witch Motion Controller/Bob are you using?
Re: Index
« Reply #36 on: March 26, 2020, 05:05:08 AM »
Please see my earlier post of March 17.
Offline TPS
  •  2,627 2,627
Re: Index
« Reply #37 on: March 26, 2020, 05:28:30 AM »
sorry i overread this, i have no experiance with smoothstepper. is it a original one or a clone?
Offline TPS
  •  2,627 2,627
Re: Index
« Reply #38 on: March 26, 2020, 05:44:48 AM »
just an other idea, a pulley is selected? and it has a Ratio?
Re: Index
« Reply #39 on: March 26, 2020, 08:47:44 AM »
Yes, the SS is original but quite old, and yes the pulley selected and ratio is 4.
I am using port 11 on the BOB witch should be ok?
