Hello
Guest
it is
November 03, 2026, 07:32:04 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
FAQs
Auto Tool Zero Problem
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Auto Tool Zero Problem (Read 49888 times)
Bob843
16
Re: Auto Tool Zero Problem
Reply #10 on:
February 10, 2020, 04:57:30 PM »
having trouble with the up loads i need to rename them
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #11 on:
February 10, 2020, 05:06:03 PM »
You have your homing and limits on Pins 10,11 & 12 so they can not be used for a tool setter so that leaves 13 & 15 one should be estop and what is the other
Last Edit: February 10, 2020, 05:07:38 PM by Graham Waterworth
Bob843
16
Reply #12 on:
February 10, 2020, 05:06:43 PM »
Sorry! There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again. error message im seeing when i try to post the rest of the pics
Graham Waterworth
2,785
Reply #13 on:
February 10, 2020, 05:12:02 PM »
I now see you have no estop, that is not good.
So set the probe into pin 15 and change the ports and pins probe input to 15 and as long as you have nothing else on pin 15 it should work
Last Edit: February 10, 2020, 05:14:04 PM by Graham Waterworth
Bob843
16
Reply #14 on:
February 10, 2020, 05:20:04 PM »
I know not having the estop was a bad idea, the tool setting and estop are what im working on i ordered the estop switch online waiting for it to come in.
Bob843
16
Reply #15 on:
February 10, 2020, 05:23:17 PM »
going to give it a try, appreciate your time working in this with me
Graham Waterworth
2,785
Reply #16 on:
February 10, 2020, 05:23:41 PM »
Ok, so estop will be going into pin 13, so your probe has to go in 15, if 15 is used for something else then you have to start linking all your home switches and limit switches into a single daisy chained input to free up one of the input pins.
Bob843
16
Reply #17 on:
February 10, 2020, 05:32:23 PM »
i dot have any limit or home switches set up pins 10,11,12,13,15 on the breakout board were empty
Graham Waterworth
2,785
Reply #18 on:
February 10, 2020, 05:46:37 PM »
Well you have then all ticked as on so turn them off if you are not using them
Bob843
16
Reply #19 on:
February 10, 2020, 05:50:23 PM »
i know its a mess trying to undo what someone else did. (children know it all's) LOL
Print
Pages:
1
2
3
Go Up
« previous
next »
