Hello Guest it is November 03, 2026, 06:36:39 AM
Author Topic: Auto Tool Zero Problem  (Read 49879 times)
« on: February 08, 2020, 04:13:38 PM »
I'm not sure I'm posting this in the rite discussion forum, i have an two sided problem that I'm hoping i could get some help or input with. The auto tool zero works intermittently, i just set it up but what baffles me is when i go over to the diagnostics tab the digitize light is lit (green) along with M2++limit,M2--Limit and M2 Home in yellow. Any comments or hints would be appreciated. Thanks in advance.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Auto Tool Zero Problem
« Reply #1 on: February 08, 2020, 06:33:46 PM »
You need to check your ports and pins settings for duplicated input numbers.
« Reply #2 on: February 08, 2020, 06:46:00 PM »
I'm on Port 1 PIn number 11 for tool setting.
  •  2,785 2,785
« Reply #3 on: February 08, 2020, 06:59:34 PM »
What happens if you change it onto pin 15
« Reply #4 on: February 08, 2020, 08:18:50 PM »
Not sure will check in the am
« Reply #5 on: February 10, 2020, 03:42:43 PM »
nothing same issues
  •  2,785 2,785
« Reply #6 on: February 10, 2020, 03:53:08 PM »
Ok, so we need some pictures of your breakout board and the settings pages in mach to work out what is going on.
« Reply #7 on: February 10, 2020, 04:01:20 PM »
ok im on it now thanks
« Reply #8 on: February 10, 2020, 04:47:36 PM »
here are the first four screen photos of the inputs next post will have the last input photo and the out put photos
« Reply #9 on: February 10, 2020, 04:54:06 PM »
next set of photos last input then out put screen shots
