Hello Guest it is November 26, 2026, 09:59:09 AM
Author Topic: Problem with calibration of axises  (Read 9649 times)
« on: January 21, 2020, 04:03:08 AM »
Hello All!
My name is Alex,
I have start work with new China CNC machine,
I installed the program MACH3 and configured lik it was write in manual instruction.
But it dos't work correct.
For example i want to did pockets diameters  10mm, 15mm, 20mm.
But i received 9.92mm, 14.92mm and 19.92mm.
i using SolidWorks CAM, Fusion 360, or  ColidCam 2013
How i can fix it?
In settings calibrate  with " Set Steps per Unit " ?
Thank you for Help!
  •  9,379 9,379
Re: Problem with calibration of axises
« Reply #1 on: January 21, 2020, 04:19:12 AM »
The calibrate function will confirm that you do (or do not) have the correct steps per unit set for each axis.
« Reply #2 on: January 21, 2020, 05:53:48 AM »
Thank you !
Can you explain more or less how i can check correct  number of steps?
Offline TPS
  •  2,627 2,627
« Last Edit: January 21, 2020, 06:13:35 AM by TPS »
« Reply #4 on: January 21, 2020, 06:25:09 AM »
THANK YOU!!
