Hello Guest it is October 30, 2026, 11:59:38 AM
Author Topic: Plugin that works for Chinese mpg pendant  (Read 89599 times)
Offline ZASto
  •  434 434
Re: Plugin that works for Chinese mpg pendant
« Reply #30 on: January 22, 2020, 01:17:46 PM »
I, personally don't use mpg. Keyboard with camera and touch plate are quite enough :)
You can buy cheap USB "endoscope" camera on AliExpress. I have one permanently installed on machine and it works with Karl's camera plugin.
Edited some buttons and added some DRO's on BigTex screenset.
Defined parking position, measured offsets between camera and spindle centre, ...
When i drill my prototype PCB's, they are NEVER aligned with X or Y axis, added some buttons with appropriate VB scripts (thanks Tweakie) to calculate the system rotation, .....
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #31 on: January 22, 2020, 01:24:45 PM »
So u use the camera to set your offsets??
Cadcam Man
Offline ZASto
  •  434 434
« Reply #32 on: January 22, 2020, 02:44:31 PM »
Yes.
I mainly work with wood and sometimes with aluminum.
All my drawings have origin at SE corner of the stock material (ie. bottom left) and Z=0 at top of the stock.
« Reply #34 on: January 22, 2020, 02:54:55 PM »
I see ...what do your PCB's do
Cadcam Man
  •  9,375 9,375
« Reply #35 on: January 23, 2020, 12:49:22 AM »
It was some 8 years ago now but if anyone is interested in circuit board positioning and local system rotate the thread is here;
       https://www.machsupport.com/forum/index.php?topic=22932.msg160769#msg160769
Offline ZASto
  •  434 434
« Reply #36 on: January 23, 2020, 02:29:51 AM »
Hi Tweakie,
what do you think where the math came from :)
Buttons A, B and C :D
  •  9,375 9,375
« Reply #37 on: January 23, 2020, 03:12:07 AM »
 ;D ;D ;D
