Hello Guest it is October 22, 2026, 07:11:09 PM
Author Topic: Mach4 Homing doesn't set DRO's to zero  (Read 10599 times)
« on: January 13, 2020, 11:03:43 AM »
Can someone tell me why, when I Ref All Home, and the machine homes to the switches, Mach4 doesn't zero the DRO's?
Re: Mach4 Homing doesn't set DRO's to zero
« Reply #1 on: January 13, 2020, 11:52:29 AM »
most likely you have non-zero home offsets in your Homing table or you have non-zero residual G92 offsets.
To check the later look on the Machine Diagnostics tab.
« Reply #2 on: January 16, 2020, 01:31:46 PM »
I have neither; however, it seems to reset to zero now. Having all sorts of issues with offsets. left an email with support.
« Reply #3 on: January 16, 2020, 02:48:01 PM »
I don't mean to hijack, but where is this Machine Diagnostics tab located? I dont see it in Mach4 Lathe.
« Reply #4 on: January 16, 2020, 04:28:24 PM »
I don't think there is a Machine Diagnostics tab in Mach4 Lathe.
I have had 'difficulties', if that is a fair description, where when I zero the Z axis as I have to do several times throughout
a circuit board job and the G92 offset has mysteriously grown from zero to 0.16mm or -0.045mm or some other random number.
When making a circuit board I need to control cutting depth to 0.005mm or better and so having what appears to be a random
G92 offset confuses the issue. Its no problem to reset the G92 but I am still bemused as to why it happens. I am making circuit
boards 'flat stick' for work and so have not really taken the time to work out why this happens.
As is often the case with Mach4 its not a fault or bug but a process or feature that I do not fully understand. Once the process is explained
then its no longer a problem. I'm hoping this is an example of the same thing.
Offline Stuart
  •  311 311
« Reply #5 on: January 17, 2020, 06:54:57 AM »
