Hello Guest it is November 13, 2026, 09:43:48 AM
Author Topic: Turn laser on and off for reference.  (Read 23445 times)
Re: Turn laser on and off for reference.
« Reply #10 on: December 29, 2019, 07:20:46 PM »
Ok still not working. I’m wondering if it’s something in the way I have my Mach3 set up.
I use a warp9 ESS and a G540 for control.
I have the two TTL wires from my laser running to port3 pin 17 and a ground pin on port3. The rest of the machine is controlled through port1 on the ESS and sent through to the G540.
M3/M4/M5 do not activate the laser I think because I have M10/M11 checked in my ESS plugin settings which to my understanding disables Mach3 settings.
Is this the case?
Would it make a difference if I connected the laser direct to the G540 port#1 output #2 instead of using port #3 on the ESS for just the laser?
Any ideas?
« Reply #11 on: December 29, 2019, 08:29:47 PM »
Ok Scratch the previous post. I Walked through all my Settings one more time and managed to find that I had a step pin wrong in the Mach3 set up. M3 and M5 commands are now working however my new issue is regardless ofMDI entry:
M3 S001 or S100 I get full power every time.
« Last Edit: December 29, 2019, 08:32:05 PM by cdelicath »
  •  9,377 9,377
« Reply #12 on: December 30, 2019, 01:14:13 AM »
My reply #3 perhaps ?
  •  9,377 9,377
« Reply #13 on: December 31, 2019, 02:45:13 AM »
Another suggestion...
If you move on to Mach4 then your ESS will allow you to gate the ESS generated PWM and Mach4 derived M62/M63 switching signals into one output which you can then connect to the TTL input of your laser. If set-up correctly this will then enable your laser to be switched ON/OFF at any chosen PWM power setting.
« Reply #14 on: December 31, 2019, 06:02:12 AM »
Thanks tweakie.
I was reading over post #3 which led me to the other original posts Because I signal active low and down the rabbit hole I went. I am completely new to this so I have to go out and research just to comprehend some of the things you where referencing. Moving to Mach4 sounds much easier. I may just manually zero the laser in the meantime in Mach3 until I get the Mach4 trial setup and learn it. Seems like it’s for the best that I make the switch.
  •  9,377 9,377
« Reply #15 on: December 31, 2019, 06:11:21 AM »
The ESS also supports laser raster engraving with Mach4 and this may be of interest to you; https://warp9td.com/index.php/faq/faq-mach4#LaserSetup
( initially it may all sound a little complex but once you get into it then it starts to make sense  ;)  )
« Last Edit: December 31, 2019, 06:13:35 AM by Tweakie.CNC »
