Hello Guest it is October 20, 2026, 07:57:42 PM
Author Topic: Circle g-code in mach3  (Read 37888 times)
Re: Circle g-code in mach3
« Reply #10 on: September 17, 2007, 05:49:38 PM »
Here you go. Thank you
« Reply #11 on: September 17, 2007, 06:48:37 PM »
You have your Y Axis step pin set as 13, that is an Input pin not an Output, that is more than likely your problem. Probably you should have it as Pin 8
« Reply #12 on: September 17, 2007, 08:58:43 PM »
thanks for your help, I'll let you know how it goes
« Reply #13 on: September 19, 2007, 07:20:25 PM »
Ok, Sorry It took me long to reply. I made the change and it made no difference. My machine is at zero location. When I click on ref y, The DRO for Y counter increases in the negative direction. but the axis it self on the machine does not move. I am trying to set the soft limits and I am getting an error of machine out of limits for softlimit activation. Please advise. Thank you
« Reply #14 on: September 20, 2007, 04:15:32 PM »
OK so to recap what happens when you Jog the X axis, does it move correctly?
Same for the Y axis, does it move correctly?
If you reference the X  it is OK?
If you reference the Y what happens?
For your softlimits issue it could be you dont have the Y axis referenced properly.
What happens when you press the Ref All button on the Program Run screen?
« Reply #15 on: September 20, 2007, 04:43:32 PM »
The manual at this link may help you with homing and limits, look in that section.
http://www.artsoftcontrols.com/forum/index.php?topic=3979.0
« Reply #16 on: September 20, 2007, 05:35:34 PM »
Also noticed Enhanced pulseing wasnt enabled in your xml that you posted. Enable it , it wont help with the above issues but usually helps overall, you will find it on the right side on the General config page.
« Reply #17 on: September 21, 2007, 09:36:44 AM »
Thanks Hood, I'll enabl enhanced pulsing.
to recap:
- When I jog x, x moves and when I jog y, y moves - no problem here
- When I ref x the y/a axis moves in the positive direction. When I ref y, the dro numbers increase in the positive direction but the y axis it does not move on the table.
- When I click on go to Z, all axis go to table 0,0
- when I click ref all, the y dro increases in the positive direction but none of the axis move on the table.
I posted 2 zip files under a different post (mach 3 strange behaviour). They have pictures of my machine and screen shots of my settings.
I also have a video that I can send you that shows the exact problem. it is 10mb file.
