Third party software and hardware support forums. > PoKeys
57e Thread Problem
(1/1)
gabedrummin:
I have a dyna myte DM-3000 Converted to run on Mach 4 .I am using a CNC4PC M-16 with a Pokeys57E .I am attempting to use a Lichuan AC Servo motor to drive my spindle and a Lichuan B-2 drive to power the 1.8 kw servo motor . I have changed all the pulleys so the spindle moves 1;1 of the drive motor . The Lichuan motor drives an idler shaft that drives the spindle shaft all have the same pulleys .The main spindle drives an encoder at 1;1 . I cant get the machine to thread, it stops on the second line of G76 code .With no error message .I can call out a spindle speed and direction and the machine will run at programmed speed and direction .Mach 4 will show the programmed speed . I have triple checked all my connections and settings and cant figure out whats wrong .I n Mach 4 I am using rigid taping . Please Can someone help me figure this out . Thank you for your help.
Navigation
[0] Message Index
Go to full version
