Hello Guest it is November 13, 2026, 01:53:19 PM
Author Topic: Nothing works, only the switches  (Read 18872 times)
Offline TPS
  •  2,627 2,627
Re: Nothing works, only the switches
« Reply #10 on: December 06, 2019, 07:47:15 AM »
usually those boards are using one pin for an enable Signal.
is there no way to figure out the configuration of WinPC CNC ?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: December 09, 2019, 06:29:41 AM »
I have looked on the web and can only find one place that advertises this board, did you get a manual with it?  If so upload it so we can work out what you need to do.
A lot of the Chinese boards use pin 9 as an enable and some need pin 1 to be fed the charge pump signal to enable outputs.
