Hello Guest it is November 23, 2026, 10:29:56 AM
Author Topic: workpiece under degree  (Read 7420 times)
« on: November 24, 2019, 09:06:50 AM »
hello i have a small cnc
i can cut 370mmx550mm
i have tu make a piece that is 560mm i can machien it under 45 degree but is there a way that i can say in mach 3 that the work piece is under 45 degree because now i have to machien over 12 hours to make the piece and 75 %is just in dead air
is there a useful video about it or a good instrucion manual
thank you for helping me
  •  9,378 9,378
Re: workpiece under degree
« Reply #1 on: November 25, 2019, 12:51:04 AM »
Not certain I am understanding you correctly but…
In the Mach3 MDI screen you could use Local System Rotate set to 45 Degrees or if you want more complex positioning you could use G68… in your Gcode file.
(User Regen Toolpath to view the work rotation)
