Hello Guest it is October 25, 2026, 10:13:19 AM
Author Topic: A-axis static feed + Spindle rpms  (Read 8668 times)
« on: November 21, 2019, 04:20:25 AM »
Hello.
I’m trying to setup Mach3 for the first time. At the moment I struggle with 2 issues.
My build are win8 connected with Ethernet smoothstepper and a servo/motor for each X, Y, Z, A, Spindle.
Issue 1: My spindle only runs around 3-4000rpm and not the 7000 I told it in Mach3. Changing the ratio 1:1 to 1:2 or 2:1 (gear adjusts in mach3) has no effect on rpm. Is it a mach3 setting or… ?
Issue2: My A-axis works with revolutions on a given distance as well as it index at any degree I define. However, I can’t get it to work with a static feed for grinding. Hints on what to do or where to look would be very appreciated.
/regards
Jacob
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: A-axis static feed + Spindle rpms
« Reply #1 on: November 21, 2019, 05:55:19 AM »
Is your spindle controlled by a 0-10V or PWM signal?
Not sure what you are asking about the 4th axis feed
« Reply #2 on: November 21, 2019, 06:52:39 AM »
Spindle is an ordinary ABB motor with a frequency modulator:
https://new.abb.com/products/3GAA091313-CSE/m3aa-90lb-2
The 4 axis are each driven by Schneider servo and impulse controlled motors.
Servo:
https://www.se.com/ww/en/product/LXM32CD18M2/motion-servo-drive---lexium-32---single-phase-supply-voltage-115-230v---0.5-1kw/
Axis Motors:
https://www.se.com/ww/en/product/BMH1001T06A2A/servo-motor-bmh---3.4-nm---6000-rpm---untapped-shaft---without-brake---ip54/
I am going to use the setup for grinding.
Some jobs I need the A-axis to index, so I can make a contour at 0, 120 and 240 degree.
Other times I need A-axis to run endlessly with a given Feed.
At the moment I only got the index to work. When I try, it only turns and then stops when jumping to next line in nc code.
