Hello Guest it is November 03, 2026, 08:49:04 AM
Author Topic: power failure  (Read 21581 times)
power failure
« on: November 11, 2019, 11:19:23 AM »
Is there any way to continue on with a project running mach 3 after a power shut down.
Re: power failure
« Reply #1 on: November 11, 2019, 11:43:08 AM »
if you shut Mach down gracefully and park the machine at a known location, usually home, at shutdown then you can continue
with a project. If however Mach does not shut down gracefully or the power is suddenly removed then NO its not possible
to restart a project without some detailed setup, ie locating the partially complete part in the workspace.
