Hello Guest it is November 19, 2026, 10:53:43 PM
Author Topic: Mach 3/winxp system crash  (Read 16067 times)
« on: September 12, 2007, 05:30:52 PM »
Hello!
I have installed Mach 3 r2.4 on my laptop, with xp installed as standard PC, 550mhz AMD Processor, 160m ram.  Mach is the only program installed with the license file in the correct location on the system with a new clean install of the xp.
When I start Mach 3 it begins to load, then, the blue screen of death, and the whole computer reboots.  I have tried normal XP install as well and had no luck.
Any suggestions?
Thanks!
Re: Mach 3/winxp system crash
« Reply #1 on: September 12, 2007, 05:35:49 PM »
try with an older version of Mach3 (1.84) and see if it makes any difference, your computer is a bit low on spec and that may be the problem. Also laptops can be problematic.
« Reply #2 on: September 12, 2007, 05:42:17 PM »
Wireless networks can cause this too.
« Reply #3 on: September 12, 2007, 05:58:33 PM »
Also might be worth trying Win 2000 as I think it uses a lot less resources
Offline docltf
  •  354 354
« Reply #4 on: September 12, 2007, 11:35:44 PM »
Bslater
       try this,reboot-go to the mach directory look for a file called special driver double click ,you will see a  quick dos screen come
       and go.then reboot.i believe that will get it.
bill
« Reply #5 on: September 14, 2007, 09:06:13 AM »
Hello!
Thank you all for your help and support!
Bill, your suggestion worked.  Seems to run real good, but havent had a chance to really get after it.
Thanks again!
