Hello Guest it is October 11, 2026, 11:12:56 AM
Author Topic: Motor pin number changes.  (Read 10121 times)
« on: September 11, 2007, 08:39:01 PM »
I have been running Mach 2 for a couple of years with very good success. I recently upgraded to Mach 3 R2.45. I am running a 1GHz computer with XP Pro. Everything seems to be working OK with the exception of the fact that the motor step pin numbers keep changing. I will correct the pin numbers (the step pin numbers are the ones that keep changing) and try to dry run a program. Most times the X axis (I am running Mach 3 turn to drive a 9 x 20 lathe) will stop moving in the middle of the program. When I check the pin assignments they are changed to something random. I tried running Mach 2 provided with this release and have the same problem. This is a licensed copy. Thanks for any help you can provide.
Re: Motor pin number changes.
« Reply #1 on: September 11, 2007, 08:46:05 PM »
Hello,
Coould you please send me the XML that is giving you trouble?
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: September 11, 2007, 10:30:28 PM »
Hello Brian,
Thank you for the quick reply. I emailed you the xml file. Thanks again...
Tim
