Hello Guest it is October 27, 2026, 03:40:16 AM
Author Topic: New Computer w/ no parallel port  (Read 24476 times)
Re: New Computer w/ no parallel port
« Reply #10 on: September 20, 2007, 05:25:15 PM »
Thanks guys,
Great news...I recieved the PCI Multi I/O card from Rogers and stuck it in the Dell 531 and installed the software(Net Mos) on the CD that came with it
and it is running a my Bridgeport with 1800 oz motors with Mach 3 and communicating perfectly.  I changed the resources hex number in
Mach 3 to what it assigned itself in Windows XP (9C00). The brand they sent was "For BEST Ports Connection" I did not check the voltage, but it is not missing steps which is usually the problem with the 3.3 volt output parallel ports. It must be 5 volts output, but I'll check with seller..
Thanks again guys
Danny
« Reply #11 on: September 20, 2007, 08:01:10 PM »
