Hello Guest it is October 25, 2026, 04:03:51 AM
Author Topic: losing steps but somehow gets back to 0.  (Read 8036 times)
« on: October 07, 2019, 01:33:14 PM »
Hey guys,
New to the forum, so please forgive any ignorance.
I have a CNC supra knee mill that i converted to mach3 last year, it ran great but as of just a couple weeks ago it started to have issues moving from 0 to where the first opperation takes place.
For example if i took a square indicated the corner, and then cut a bore in the middle. the bore would be in spec, but located .030ish to the X negative. and then it would go exactly back to 0.
Ive also run old programs that i knew were in spec when i did them, and they display the same issue.
If anyone could help, or needs more information, I would be extremely appreciative.
Thank you,
Calvin
  •  9,374 9,374
Re: losing steps but somehow gets back to 0.
« Reply #1 on: October 08, 2019, 12:31:54 AM »
I would suspect a mechanical issue is the cause - perhaps something loose ?
« Reply #2 on: October 08, 2019, 04:03:00 PM »
I would look at the Steps Per settings for that axis. Missing steps would not return to zero and most times a loose connector will not return to zero. It is possible the XML got corrupted and the value is now wrong.
Just a thought , (;-) TP
