Hello Guest it is October 21, 2026, 05:06:52 PM
Author Topic: Y axis moving in the wrong direction  (Read 63860 times)
« on: October 01, 2019, 06:19:34 PM »
I am brand new to cnc machines and I just set up the SainSmart Genmitsu CNC Router Machine 3018-MX3, with Mach3 Control. I am running Window 7 pro 64-bit. After setting up and installing software the Z-axis and X-axis are moving in the right direction, however the Y axis is moving in the wrong direction; when the workbench moves back towards the Y-axis stepper motor my read-out is – minus numbers and when I move away from the stepper motor its reading + numbers. This is after Sainsmart customer service sent me a pdf file for how to correct the problem. I went in to configuration, ports & pin, and then motor outputs as instructed in the pdf sainsmart sent and made the correct changes but the Y axis is still moving in the wrong direction? Can anyone help me with this? Enclosed is the pdf instructions they sent me…
Thank you,
DesCas
  •  9,374 9,374
Re: Y axis moving in the wrong direction
« Reply #1 on: October 02, 2019, 12:18:40 AM »
As mentioned in your attached .pdf file - changing the Direction Low Active state of an axis (and saving the changes) will cause that axis to move in the opposite direction.
It is a bit confusing because the correct direction is really the direction the TOOL moves in relation to the work and if you have a moving table then the table has to move in the opposite direction to achieve this.
Hope this helps.
« Reply #2 on: October 02, 2019, 09:23:49 AM »
Thank you… that makes sense now. I did learn how to change directions but for the time being I’m going to leave it as is. I have much to learn...
