Third party software and hardware support forums. > SmoothStepper USB
USB Smooth stepper and Mach3 problem
(1/1)
JimKal:
Hi All
I have a problem and I suspect that the Smooth Stepper board may be faulty. When an estop is triggered, mach3 continues to make the triggered estop noise at a regular interval after the initial estop is activated. I have checked all inputs to the Smooth Stepper board and also disabled all limit switch inputs in mach3 and this does not stop the problem. I have tried an external 5V power supply to no avail and I have obtained and installed a new copy of mach3 in case it was somehow corrupted. I note also that the problem still perseveres when the Smooth stepper is disconnected from the breakout board. I am now wondering if the Smooth Stepper board or the plugin is the problem. Any suggestions would be appreciated.
Regards
JimKal
Navigation
[0] Message Index
Go to full version
